vcGetProductsStatement
Get products statement.
ContainervcContainerRWGets or sets the component container to read the Product Instances from.
FiltervcProductFilterRGets the filter.
MaxCountPropertyvcExpressionPropertyRGets a property defining the maximum number of Product Instances to return. Leaving empty and negative values mean no limit.
VariableNameStringRWGets or sets the name of the Process variable to use for storing the result.
demoteFromCombinationFiltervcProductFilterNoneDowngrades back to filter, filter count must have 1 or 0 filters.
vcProductFilter: The modified filter.
TypeError: When the filter is not a CombinationFilter.
TypeError: When CombinationFilter has more than 1 sub-filters.
promoteToCombinationFiltervcProductFilterNoneUpgrades current filter to combination filter.
TypeError: When the filter is already a CombinationFilter.
replaceFromvcProductFiltervcStatement statementSets filter from other container.
statement (vcStatement): The statement to replace the filter from. Has to be a statement with a filter container.
AttributeError: When argument is a statement without a filter container.
setFiltervcProductFiltervcProductFilterType filterTypeSets to specific filter.
filterType (vcProductFilterType): The type of filter to set to.
vcProductFilter: The new filter.
AttributeError: When the argument filterType is ProductType.
NameParametersDescription
OnFilterChangedNoneTriggered when filter is changed.
